Sold PG Tantrum 600.4 and CDT Mids!
Logikalliquid
I need to do some cleaning after paying for this semester's books.
Phoenix Gold Tantrum 600.4 Asking $200 shipped
• 4 channel power amplifier
• 18dB HP/BP/LP variable crossovers
• Crossover configured aux output
• Low Pass Level port (LPL)
• Dimensions: 14.25L x 10.0W x 2.35H
75W x 4(4 ohm stereo)
150W x 4(2 ohm stereo)
300W x 2(4 ohm bridged)
I have the original birthsheet, manual and box(not pictured) I will also include the LPL44 remote gain knob with the amp so you can adjust the amp from your seat.
PICS:
CDT HD-6 Midrange speakers NIB Asking $130 shipped
I was going to build my own component set using these and the amp above, but priorites change :/ I never got around to using these. 1 speaker is still in the plasic it came in!
-6.5" Cast Contoured Dispersion Mid. feature "Contoured Dispersion" radiation pattern in the critical midrange frequencies, delivers rock solid imaging and front staging, with virtually no side biasing. "Audiophile" sound, smoother response, wider dynamic range, and better imaging and higher reliability.
-high quality 6.5" magnesium cast basket, woofer with curve linear design carbon treated paper cones. Stainless steel top and bottom magnet plates for better heat transfer and dissipation.
-ceramic 14.6 oz woofer magnet
-gold plated terminals
-butyl rubber surrounds
-flat spider-allows a consistently linear cone excursion
-25mm high temp aluminum voice coil former
-130 watts power handling- at 100 Hz High Pass
-frequency response 55Hz-7kHz flat(6.5-octave response)
-Sensitivity 93.10 dB (2.83V)
-4 Ohm
-recommended high pass x-over point 65-90Hz
-recommended box design 5.8 liters
PICS:
Sorry, but I will have to pass on the CDT mids. After pulling my C6 vette door panels off and digging deeper into what I need, I actually have room for up to 8" drivers. Very good deal, but not right for my setup like I thought....thanks.
Logikalliquid
Logikalliquid
SoVA
rvpps2rocks
