pg rsds
ordered mine from audiosavings on a saturday the 22nd, they shipped out ont he 24 and the estimated delivery was supposed to be here on the 28th(today) but being that postal was on a hold for christmas, fed-ex bumped me till monday the 31st... :/
I just ordered the pg rds comps and coax's from audiosavings also. I also ordered a kicker 350.4 to power the comps up front and coax's in the rear. I see that some of you are pushing alot more power...did I make a mistake? I'm just looking for a nice upgrade from my crappy factory speakers powered by my kenwood HU.
you'll be fine. they will still sound good but they love more power.
What kind of car is it? If it is a smaller car (coupe) you should definitely bridge the amp to power the RSd's and run the rear fill off of the head unit.
Thats great advice guys! I never thought of doing that. So this is definately the way to do it? I thought the extra bass in the rear would help.
nah, if you care about SQ then you want most of the sound coming from the front. you actually want the front speakers to play as much of the low end bass as possible w/o distortion and bottoming out of course.
i have my rsd's high passed at 63hz and my sub at 50hz both with 12db crossover slopes and they blend together very very well. on most music you'll hear the very bottom end but it actually sounds like it's all coming from the front speakers. it almost sounds like i don't have a sub in the trunk. the only time it's obvious that i have a sub in the car is when i really crank the volume up and you feel the double bass kicks in your back.
my point is if you have bass or mid-bass really coming from behind you it will pull the sound stage to the back and it won't sound the same. some people though prefer that sound, it's all up to you in the end.
Thanks for the great advice tcguy85. Now I'm wondering if I should return the 4channel for a higher rated 2ch amp. Would it be worth the hassle? I'm not running a sub and just wanted a simple upgrade from my factory speakers, but if it will make a big difference, I'm willing to do it right.
Like they said, just bridge it. You don't need to run lower than 4ohms so you're fine.
doyoshuffle5
doyoshuffle5
lowell, in
StupidDumbSlap
BP1Fanatic
BP1Fanatic
