So, my setup is a 10w6v2 in a sealed box running off of a MRD-500 at 2ohms. I have a stock head unit with all the bass +treble at zero. I used a 50hz test tone and set my gaisn to the desired voltage. I also set the LPF at 80hz. Then i set my Parametric eq to 45hz center freq, 3db boost, and 2 "Q". My question is, when setting the Parametric EQ too high would my amp start clipping? Would i have to lower the gain in order to compensate with the EQ?
Thanks and sorry for the newb question.
