Pair of Tens...
Got brand new 12" 300 watt each Fusions, here is a pic and the info, I am looking for 100 shipped, they have full warranty on them, thanks and let me know if there might be anything else your looking for!
Encounter 10" Dual Voice Coil Subwoofer
Dynamic Response Butyl Surround
The soft, flexible butyl rubber surround ensures cone movement is controlled while producing punishing bass
Thermal Transfer Vent
Thermally efficient exhaust vent diffuses heat produced during extended excursions into extreme low frequencies
Protected Motor Assembly
Encounter’s rubber boot protection system securely encases the motor structure for any installation situation
Chemically Treated Cone
Green invasion, high impact, chemically treated cone to resist moisture and other environmental threats
Detailed Finishing Gasket
Contrasting silver finishing gasket ring
Heavy Duty Speaker Terminals
Optimal connection with heavy duty ‘push to play’ terminals
Polished Chrome Chassis
Solid basket chassis, protected and detailed in chrome
Product Specifications
Max Power Rating (Watts): 300
RMS Power Rating (Watts): 150
Coil Height (Hvc): 20
Compliance (Cms): 328.1
Cone Area (Sd): 34.9
D.C. Coil Resistance (Re): Dual 3.6
Electrical Q (Qes): 0.433
Force Factor (Bl): 16.644
Free Air Resonance (Fs): 29.1
Frequency Response: 25Hz - 3.5kHz
Impedance (Nominal): Dual 4
Linear Excurson (Xmax): 7
Mechanical Excursion (mm): 20
Mechanical Q (Qms): 3.492
Moving Mass (Mms): 91.266
Magnet Structure (Oz): 43
Sensitivity (dB) (1W/1M): 87
Total Loudspeaker Q (Qts): 0.386
VAS (L): 56.74
VAS (CuFt): 1.98
robspeed2002
robspeed2002
Sillicon Valley
6spdcoupe
