Sold (pair) 6.5" Tang Band, NEO. Mid-Bass / Sub driver
tristanmay
want to trade pair of tang Band W6-1139SI
interested in pretty much anything
might sell for right price.
Amazing bass in a compact package! This one-of-a-kind 6-1/2" subwoofer has an impressive 13 mm of Xmax. A wide roll surround, raised flat spider, and large 1-1/2" 4-layer voice coil ensure impressive bass performance and high power handling. Venting the pole piece and spider allows good airflow around the coil, improving heat dissipation and reducing power compression. The compact neodymium motor structure saves valuable enclosure space while also allowing closer-than-normal placement to CRTs. The ultimate multimedia subwoofer driver! Specifications: Power Handling: 50 watts RMS/100 watts max *VCdia: 1-1/2" *Impedance: 4 ohms *Re: 3.6 ohms *Frequency range: 38-800 Hz *Fs: 38 Hz *SPL: 83 dB 1W/1m *Vas: 0.416 cu. ft. *Qms: 2.65 *Qes: 0.47 *Qts: 0.40 *Xmax 13 mm *Dimensions: Overall diameter 7", Cutout diameter 5-1/2", Depth 3-5/8".
Long-throw, high-power design for more bass -- 13 mm Xmax!
Paper cone with oversized roll
Neodymium magnet with vented pole piece
Steel basket
Magnetically shielded
sweet! sold to SUPERMAXX!
this will go twords my "I owe phill alot of money" fund!
also PM box will be empty in a min
EDIT! also supamaxxxxx check with phill on the specs of the sub, its an Elemental Design's 7Kv.2
cant find info on it //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
tristanmay
tristanmay
medina, ohio
tristanmay
