It's already rounded and smooth as can be. So just any paint in a can really?Make sure glue and edges are rounded will help with the look and use any type of glossy paint etc. try to do 2 good coats.
If the box is smooth so will the paint be just do 2 coats and make it as smooth as possible with no drips paint really matters to you... I prefer to rhino line and then paint for the better look.,It's already rounded and smooth as can be. So just any paint in a can really?
---------- Post added at 12:58 AM ---------- Previous post was at 12:57 AM ----------
BTW that was the quickest reply I've ever encountered. Kudos.
Okay. Thanks for your help.If the box is smooth so will the paint be just do 2 coats and make it as smooth as possible with no drips paint really matters to you... I prefer to rhino line and then paint for the better look.,
That looks like the easiest option. Does it come in a variety of colors? Looking for dark black and bright red.If you wanna use actual paint and not bedliner, this stuff works great, I use it on nearly all of my boxes, only $8/can at home depot: RustOleum.com
It does come in other colors, but only other neutral colorsThat looks like the easiest option. Does it come in a variety of colors? Looking for dark black and bright red.
