ok wut i have here is a delco remy pad mount style alternator, from factory it is a 150 amp it was beefed to a 200 amp, the case is stamp with 200 amp, the alt was not used after rebuilt, so it is consider new. of remanufactured. these is a unaversal style alt meaning that all you do is hook a ground to it, and hook a wire from your batt to the one power terminal on the back and thats it, there is a chip in side of it, so wen if feels a draw the altput out more, the more of a pull on the eletrical the more it puts out, pad maount makes it easer for applaction becuase you use spacers under the 4 legs then mount to a 1/4 steel plate then the plate to you ccar,, here is the web site for dimension purpose.
http://www.delcoremy.com/Alt22SI_HP.aspx
price is 110.00 shipped which means after shipping and paypal im only getting about 80.00 contact me if intrested
