package
Also, I wouldn't go with option 3 for a pair of the SVC memphis subs. You can get more power for $10 more. http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4879
Personally, for a liiiiiiiiiiitle bit more I'd buy it from crutchfield. DEFINENTLY if you want to install it yourself. http://www.crutchfield.com/S-XS724r7Im7x/cgi-bin/ProdView.asp?g=120&tab=essential_info&i=489HA1040#Tab
As far as a box.Yet again, there are plenty of builders on here, including myself.But I'm sure there's on in Ohio.
Avoid that kind of stuff if you can. Especially that DUB stuff. Kicker makes good stuff, but that's their low-level stuff in that package. If you're interested, I have an Eclipse SW8102 (same as the TC Sounds TC-7). I could build a box for it too. Sell it to you for $175 plus shipping including the box. I'd have to do some looking to find the right amp to go along with it.
-Also, shops will normally charge at least $50 an hour to build a box for you. You'd definitely be better off having a forum member do it.
i think im pretty much going to get the 2 memphis subs and mountaineer man you say go with the sub you sent me instead of the one that was in option 3 ? if its about the same then id deffinetly go for that one because its 30 dollars cheaper
Crutchfield has VERY VERY good customer service.Some of the best.If you were to accidently fry it during the install, they'd replace it no questions asked.They also have a tech line if you ran into any problems/questions during your install.Basically, it would be possible for you to do it with their tech line.They're used to walking people through installations.Not to mention you get the factory warranty. It's really not that much more expensive from them when you consider the benefits.
I'd say the two memphis subs and that amp I linked you, bridged.Knu konceptz for wiring (high quality, good prices).
I suggested that amp because it has more power, and it's $10 more at the same place. http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4879 would be your best bet IMO for power to cost ratio.
Profile amps are IMHO the best budget amps.In my experiences with them (and so many others I know) they have been beyond reliable.
Jcool
Jcool
medina, oh
Jcool
