Sold P.G. Tantrum 1200.1 and 600.4
BassAddictJ
Up for sale are two awesome PG amps. These were the last series made by PG that kicked ***. USA made, underated as hell, built like tanks. Semi-old school (both were made in 2002). Other than a little dust between the fins these amps are an easy 9/10 cosmetically. Very good condition considering they're over 8 years old.
The 1200.1 looks great and works great. These 1200.1's are known for doing a good 1400w rms at 2 ohm, and i believe 1200 at 4 ohm (please post if this needs to be corrected, i know crutchfield and sonicx online specs aren't always the most accurate). It has a variable 18db SSF from 5hz to 50hz (always an awesome feature), 18db lpf, and switchable hpf/lph/bypass for both the amp and the aux rca outputs for another amp. Fan cooled and ready to rock.
here's a bigger list of specs:
High Efficiency Class-T Circuitry
Thermally Efficient Heatsink
Timed Acoustically Integrated Muting (TAIM)
Differential RCA or Speaker Level Inputs
18dB / Octave Low-Pass Crossover
30Hz to 300Hz Continuously Variable Crossover Frequency
18dB / Octave Subsonic Filter
Variable Twin-"T" Bass EQ Circuit Provides Up to 18 dB of Boost at 45 Hz
Optional Accessory: RMD Remote Monitoring Display Port
Optioanl Accessory: LPL Low Pass Level Controller Allows for Driver's Seat Adjustment of Bass Volume
2 Ohm Stable
Amplifier Type: Mono
RMS Power: 600W x 1 @ 4 Ohms
Bridged RMS Power: 1200W x 1 @ 2 Ohms
Speaker Level Inputs: Yes
Preamp Outputs: No
Built-In Crossovers: HP/LP
Bass Boost: 0-18 dB
200 shipped.
EDIT i bought this 600.4 and was told 2 ch did not work on it. I took it home, opened it up and didn't see any damage....bench tested it and everything works as normal. all 4 channels checked out perfect individually and bridged. AC output voltage was consistant with what it should be at and DC bias was right within the normal levels it should be at.
It seems the previous owner had something else wrong in his setup and assumed it was the amp. It passed my bench test flawlessly //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
rear channels have a bandpass crossover, that's pretty awesome //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
new price, 120 shipped
more specs for the 600.4:
Tantrum Series 4-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 75 watts x 4 chan.
2 ohms: 150 watts x 4 chan.
Bridged, 4 ohms: 300 watts x 2 chan.
Thermally efficient heatsink
Differential RCA or speaker level inputs
Tri-linear capability allows simultaneous stereo and bridged operation
18dB / Octave High-Pass, Band-Pass, and Low-Pass Crossovers
40Hz to 800Hz Continuously variable crossover frequency
Auxiliary outputs route inverse crossover signals
Variable Twin-"T" bass EQ circuit provides Up to 18 dB of boost at 45 Hz
Optional RMD remote monitoring display port
Optional LPL low pass level controller
2 Ohms bridged stable
Amplifier type: multi-channel
Speaker level inputs: yes
Preamp outputs: yes
Bass Boost: 0-18 dB
Frequency Response: 20-20,000 Hz
Dimensions: 19.25"L x 10.0"W x 2.23"H
120 shipped
both amps for 300 shipped
send payments as gift so that i dont have to eat the feeez. or add 3% for feeeez
paypal is jaym_productions@Yahoo.com
BassAddictJ
BassAddictJ
FL
denim
