This man is mechanical engineer....and he has over 10,000 watts to each of his speakers in his car...I've seen it, he lives next to a nuclear power plant and uses cold fussion molecular generators as amps //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.giflol. tell me how its gonna blow? the reason being so many people blow their speakers is the reasons stated above. thats how i blew my tweets. easy, i could hook up a 10kw sub to any speaker and won't blow. i'll have the volume at 2/80 with the gain down. i just proved it. READ.
no such thing. you can never blow a speaker as long as the speaker doesn't see frequencies it isn't supposed to see and that the amp is not getting excessive clipping. if you avoid those two, most of the time you will never blow a speaker.
huh? i said that? where?You did not specify at low volumes or with a limit to output based on gain. What you said assumed full wattage and full amplified output at 100% volume.
shhhhhhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!!This man is mechanical engineer....and he has over 10,000 watts to each of his speakers in his car...I've seen it, he lives next to a nuclear power plant and uses cold fussion molecular generators as amps //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
What I mean is this, by not including the clause, "limiting power by adjusting gain" it is to be assumed that the amplifier will be set up to deliver it's full unclipped power with an unclipped signal, in my case 10kw.no such thing. you can never blow a speaker as long as the speaker doesn't see frequencies it isn't supposed to see and that the amp is not getting excessive clipping. if you avoid those two, most of the time you will never blow a speaker.
