overheated!! help!1
cf680c2
ASIA
hi all... Am using a BOSS rev-800 to power up 2 12" woofers, the AMP went into protect mode after 1/2 an hrs due to high temperature.. is there anyway to reduce heat?? or the amp is not suitable for my woofers?? woofer spec: 4 ohm max 600w
Well, the amp is definately where the problem lies. Boss amps unfortunately are not of the highest quality and thier circuitry is far from suitable for car audio.
Likely the final impedence of the woofers on the amplifier was to low for the amp to handle therefore it went into protection.
Sorry for the bad news, but the amp has got to go.
Take it easy,
-zane
Lanzar, Power Acustic, MTX
all very cheap amps
not to bad
I agree the BOSS amps cant handel very much
Make sure thoes subs arent bridged...cause that amp im pretty sure cant handle a 2 ohm load mono
At least thats what it sounds ilke
MY POS 1500 Power Acustic amp does the same but I keep it super cooled so its fine
Originally posted by julian:any amps to reccomend? prefferably cheap amps
I have quite a few that could easily work for your system. Are you looking to stay within a certain price range?
There are several amps out there that are worth thier wieght in gold that dont cost an arm and a leg.
Take it easy,
-zane
235
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
256
497
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
305
cf680c2
cf680c2
ASIA
zane
slater
    May 2, 2024
slater
    May 2, 2024
