over heating
Burning coolant was suggested merely in the case of blown head gasket. You are correct, under normal circumstances coolant wont burn or ever reach the combustion chamber. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i havnt checked this thread in a while, but thanks for all the suggestions/help.
im not sure about the fail safe thermostat but when it does heat up , its only to the 3/4 point. at about 4/5 or so the check gauges light will come on and it hasnt done that since i started this thread. only when i jump on it will it get that hot.
other than that it runs fine. havnt had any other problems.
as far as changing coolant , do i need to get it flushed like they do with transmissions or just empty and refill? i think ill get around to doing that today since its my day off.
Coolant won't burn... Even when it does make it to the combustion chamber... Blown head gasket or not.
I dunno man i read that statement a few times and haven't come up with a conclusion. You are the first to ever tell me that coolant doesn't burn. I know coolant has a lifted boiling point, but if combustion temps reach say 1600º F and said coolant is entering that flame front i would imagine it getting burned, it getting pushed out the exhaust valve(s) and it venting a white cloud of sweet smelling smoke(steam?) to the atmosphere.
Not flaming you at all, would just like to know your side of this!
Sorry for hijacking thread
Maybe you should walk or bike if it's only 2.5 miles away ...
... i live in miami, no thanks.
well im going to flush teh radiator today since its nice and cool out (~75).
fluid , cap , thermostat/gasket...anything else i would need?
done.
the old thermostat looked like shit. put the new in and let it run for ~15 minutes. didnt get hot at all. but when i went to check the level of the coolant , it was low. filled it again , let it run for a minute and checked, coolant dropped. a friend came by and helped me look around for a leak and we couldnt find anything. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
after i clean up ill take it on a ride and see how she does.
sqhertz
sqhertz
Miami ,Fl
sqhertz
