I love that smiley //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif It's so wrong, but yet...so right //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Well, what kind of tube amps are you looking at? You could pick up a decent Magnavox console amp that uses push/pull EL84 pentodes off
Ebay for that price range, but IMO, single-ended triodes are going to give you more of the "tube sound". There are SET's out there for $250, but you have to watch Audiogon and
Ebay for them. Expect to get around 2 watts per channel with EL84's/6BQ5's. 5-9 watts single-ended is going to be more pricey, but push/pull can be easily done.
This guy:
http://abraxasaudio.home.att.net/quicklist.html is building my next amp for around $700, but I don't know what he charges for smaller projects. A used pair of Antique Sound Labs Wave 8 monoblocks would fit your budget at around $200 for the pair, have 8 watts per channel, and give you a good taste for tubes. The only two drawbacks are that they're push/pull, and use solid-state rectifiers. But, they're a good place to start. They come up on Audiogon and
Ebay every now and then.
The only problem with Adire's kit is that it uses a crossover - it would probably be cheaper to get two Fostex or similar high-efficiency full range drivers, and build a backloaded folded horn for it. No crossovers needed at all.
A standard receiver would work if it has a pre-amp output - I know my NAD does, but I'm not sure all do. And that's only a concern if you buy a power amp. Of course, an integrated tube amp will have a driver stage. I'm selling my all-tube preamp, but it's basically your budget right there //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Tubes for HT? Well, it can certainly be done, but not for $250. You'd need big power pentodes or tetrodes, something like a few KT88's running push/pull for around 40-50W per channel, so monoblocks running to an external Dolby processor would be the way to go. It would be expensive, but quite a sight. And of course, the subwoofer amp would have to be solid state anyway.
Hope this helps...PM me if you have any more questions, or catch me over on SSA //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
