Other alternatives
  • Thread starter -Sin-
  • Replies 0
  • Views 300
-Sin-
IL
I've seen Secondskin's OverKill and RAAMaudio's Ensolite just wondering if anyone has used other alternatives? I have heard of people using carpet padding for the doors and such and I found this at Mc-Master-Carr.
Part Number: 86225K23 $48.26 Each
Material Type: Polyurethane Foam
Properties: Oil Resistant and Abrasion Resistant and Tear Resistant and Impact Resistant and Weather Resistant and Chemical Resistant and Electrical Resistant
Backing: No Backing
Thickness: 1/4"
Thickness Tolerance: ±0.025"
Length: 10'
Length Tolerance: ±5"
Width: 54"
Width Tolerance: ±1"
Temperature Range: -20° to +150° F
Cut With: Scissors or Shears
Tensile Strength: 20 psi
Stretch Limit: 150%
Density: 2 lbs./cu. ft.
Foam Structure: Open and Closed Cell
Texture Type: Coarse Cell
Foam Firmness: Very Soft
Firmness, psi: .60-.85 (25% Deflection)
Compression Recovery: Good
Color: Gray
Finish: Textured on Both Sides
Tolerance: Standard
Specifications Met: Underwriters Laboratories (UL)
UL Specification : UL 94HF1
Notes: Material does not have a skin.
-Sin-
-Sin-
IL
-Sin-
