here are the specs and some of the price ranges i came accross , i dont have a price for them myself since i did play them for a month and a half i dont know what i should sell them for now ... i paid 470 a piece and they have them on
ebay buy it now for 350 and free shipping so im not sure what you guys think? oh and i forgot to mention they are already in a groundshaker box which was 80$ and well the subs are leaving with the box since im in no need of the box either im now more worried about my newborn and well shipping costs i dont know the whole thing being 2 subs in the box weighs easy 180 pounds.
# 12" HCCA Series Subwoofer
# Sensitivity: 84 dB
# RMS Power Range : 2000 Watts
# Peak Power Handling: 4000 Watts
# Impedance: 4 Ohm
# Diameter: 12 Inch
# 4" copper Wound Voice Coil on an Aluminum Former, High temperature Polyester Amide, Amide Resin Coated
# Continuous power handling will be 1500W (under rated)
# X-Max estimated at 30mm (total travel 4 peak to peak)
# Field Replaceable Cone / Voice coil / Spider Assembly
# Dual Flat Spiders with Loop/Stitched Tinsel Leads
# Tall, wide, balanced, Foam (high density expanded polyester foam) surround for linear controlled long excursion using a Tri-Radius symmetrical edge design optimized on non-linear FEA
# Enhanced voice coil cooling system forced convection with aluminum heat sinking shorting rings to reduce inductive heating)
# Dimensions (in) 11.9 x 10.7
