Orion 8002 and 4004?
crewcab
I did an install and was given an Orion 8002 and 4004. There are in mint condition and in working order. I've never used these amps, are they any good? I have type x componets and mid bass drivers for front stage. I have an mrv-f345 to power them with. My question is the orion amps would look great together for an install but is the 4004 going to do as good as job as the Alpine?
sold my 8002 to a guy local...he smoked it not 2 months later and junked it...sigh //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
solid amps, had some power
What are you using it for? If you are powering a sub, yeah the 8004 would be nice. But if you are just running front speakers then the 4004 is fine. It does 200 watts x 2 at 4 ohm, plenty for a front stage.
I'm going to use the 8002 for sub. You can bi-amp the type x componets so i planned on running 2 channels to the 5 1/4's and the 6 1/2 mid bass drivers and 2 ch. to the tweets. Unless bridging the componets and mid bass drivers together would be better?
****, i need a Orion 8002
If you decide you want to sell it,let me know!!
Or we can trade my orion 6002 + some Cash$$[/b]
Features:
Intelli Bass variable bass equalization
Separately adjustable, variable 2-way active crossovers with proprietary Copy/Master control circuit for RCA outputs
Copy/Master feature supports high-pass, low-pass, or bandpass configuration and gain matching for multiple amp systems
Mono/stereo switchable
Heavy gauge direct-wire high current satin finish power and speaker terminals
Specifications:
Power Output:
2 x 150W @ 4 Ohms
2 x 300W @ 2 Ohms
1 x 600W @ 4 Ohms
Signal Processing:
Variable low-pass 20Hz to 3kHz
variable high-pass with INTELLi Q 10Hz to 3kHz
10dB of bosst with INTELLi Q
remote gain capable
selectable AUX out
Fuse Size: (1) 60 MAXI
Dimensions: 22.4" x 10.5" x 2.3" (569mm x 267mm x 58mm)
crewcab
crewcab
Enid,OK
jesseixe
