Orion 2500d
walkychalky
I am thinking about buying this amp to power 2 RE SX 15's but i have a couple of question about it first and was wondering if anyone could help me out with them
First, On most sites it says this is a 2500w RMS @ 1ohm but i looked on the orion website and it states 2500 as the max for this amp....but it doesnt state the RMS.....i was thinking this maybe means that 2500 RMS is the max this put out between the diff power ratings.....like it gives 1200 @ 4ohm 1700@ 2ohm and it puts out its max at 1 ohm which is 2500.....would i be correct in assuming this?
Second, If i wire this amp to 2 dual 2ohm subs i can get a 1ohm load right??
I have found a great deal on this amp and could use this info as fast as anyone can give it to me so i do not miss out....thanx in advance for ur help //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Sorry for questions if they are simple.....but i am quite a noob //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
2500 watts rms and then some. it also makes rated power at 13.8 volts. you only wiring options are 0.5 and 2 ohms. these amps have been known to handle 0.5 ohms daily, but that would be up to you. have you purchased the sx's yet? you could try to get RE to make them into dual 4's if you haven't bought them yet.
Hey I was thinking about hooking this same amp to my two 15" Kicker L7s DVC 2. Ive heard the L7s can handle 1ohm but would it be ok running at 0.5ohms? How many rms would each sub get running them at 0.5 ohms?
Each sub will be getting 1250 ernesto, same for the Viper D2500, lets ride to ikesound thursday and get it.
Off topic...why isn't anyone interested in the KX2500.1 from kicker? I was on Ebay and they have them for around 500.00 bucks.//content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif Maybe its funds...//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
$500 for a KX2500.1? P/M me the link. I would prefer a KX2500.1 than an Orion or Viper.
walkychalky
walkychalky
San Jose, CA
SBLAZER
