60ndown 10+ year member CarAudio.com Veteran 3,661 1 ca Mar 3, 2006 #1 does it have fuses on board? what amperage? Click to read more...
n2audio 5,000+ posts OPTIDRIVEN 5,690 86 Lawrence, KS Mar 3, 2006 #2 manual says "none" http://www.directeddealers.com/manuals/og/orion/G47395.400.405.410_11-04.pdf
TypeRBass 10+ year member Walls are for wussies 3,357 15 Tinley Park, IL Mar 3, 2006 #3 no there are no fuses. you have to install a fuse on the power wire coming off the amp.
OP 60ndown 10+ year member CarAudio.com Veteran 3,661 1 ca Mar 3, 2006 Thread Starter #4 ok no fuse, so i need to install a 100 150 200 250 (how many amps?)amp fuse in the positive power line? daily driver headroom not spl.probably be useing the amp at about 1/3 of its full potential.
TypeRBass 10+ year member Walls are for wussies 3,357 15 Tinley Park, IL Mar 3, 2006 #5 eh i run mine on 160amps of fusing daily @ .5 ohm. so you'd be fine with that. i'd say do the 150 amp.
