Orion 2500D Amp - WCC-D5000
KingOfBling
Hi, i wanted to ask if any of you guys knew what was the difference between
Orion 2500D Amp
and
WCC-D5000 Amp
I was going to purchase a Orion 2500D but my cousin knows a guy who has a WCC-D5000 he is selling for $400 CASH, but i dont know what the difference is between the two other than the badging.
Also if i run my L7's in 1ohm mode and use either of the two amps can anyone tell me if the two woofers split the 2*** watts or how does that work ?
Thanks looks like i will go pick it up from him.
One other question, which gauge power wire would work best ? 0 or 1 ? or which
Right now i have 8 gauge power wire installed from my old amp but i know that wont work so thought i would ask which would be best.
1/0 is good for current delivery,
(reminds me that I need to install my 4/0 //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
Hey guys i have another question,
Im hooking up the amp but i dont understand the speaker wiring in the booklet,
im going to be running some Kicker L7's DVC 4-ohm and i was told by someone else that i needed to run them into one to make 1ohm (+,+ -,- into only two wires instead of four) however in the amp booklet it says not to run the speakers bridged ?
So how would i hook these up to the amp ? Just plug in +,- +,- into the terminals and move on ? Im a little confused.
thanks
hook it up with the + wire from the speakers going into one postive on the amp, and the negatives from the speakers going into the negative from the other side of the amp
so:
+, skip -. skip +, -
KingOfBling
KingOfBling
Dallas
denim
