orion 2100 and 2250
michaellane
Hcca 2100 pics
http://s1340.photobucket.com/user/m... Uploads/20170203_200722_zps9ji6bblk.jpg.html
Orion hcca 2100
Orion 2250sx the beast
2250 sx
Got this along with the 2100 awhile back. Bottom plate has been cut so you can remove wires easily I'd assume. I am not the original owner. Amp works great and actually sounded better then I would have guessed. I only have one set of set screws for the power and ground between the 2 orions I figured I'd send them with which ever sold first or before shipping head to ace and try to find soemthing that would work incase I needed to test the remaining amp again before selling. Over all condition I'd say 6.5-7 out of 10. I have one harness between the 2 orions also but it was bought off ebay for idk 30 bucks maybe. Anyways on to the pics
That's the info on the 2250
Got this and the 2250 awhile back. Clearing out some of the stuff I'll never use and this is one of them. It is missing the bottom plate. I got it like that but had always planned on putting a piece of plexiglass down there. The amp works and sounds awesome. Now I do know some of the 2100's came like this while most were red. I don't know it this was changed or if it came like this factory. I am not a big orion guy honestly. Overall condition I'd say 6-7 out of 10. Others may rate it higher or lower but I can say I would NOT hide it in my own install. Any other pics needed or wanted just let me know. To test it I used the 12v power supply big d reviewed which is actually pretty nice. If anyone was curious. I will give the 2250 a look over tomorrow also.
Took some pics with flash and some without
That's for the 2100
400 and 400 I'll take trades heavy on my end. Heavyyy
---------- Post added at 06:59 PM ---------- Previous post was at 06:59 PM ----------
2100 was stripped by one of its previous owners. Still looks good
---------- Post added at 07:00 PM ---------- Previous post was at 06:59 PM ----------
Also, I have removed the anodic coating on one before, and it does not come out like that, I speculate it left Orion in that finish, could possibly be one of the 21, I wonder what happened with that truck, might be still whole somewhere but I doubt it.
Ok, I will bite, how would you have gotten the coating off between the fins and when you use a stripper it discolors the heck out of the aluminium, I said I tried 1 time, I ended up throwing the thing in the garbage, it turns out bad.
Did you put in the time to hunt the picture down? it is out there try keywords , yellow orion dually, there is also a white van with a bunch of 12's and literature pockets in the back swing out doors.
michaellane
michaellane
tx
wew lad
