Orion 1200d and 4002 help me plz
CrazyKenKid
Hi all,
okay here i go. first i ran my wiring down the right side (pasenger side) like all my wires power, 12v, and output(rca). i hooked up my 4002 amp and everything worked 100% np at all what so ever, i am running a pair of pioneer 5way 460watt 6x9's.
now i install my 1200d right next to it (about 4-4.5in away from it) and run the wiring all in the same spot. then i turn on my car to see if it all works and out of the speaks i get this buzzing noise kind a like i am getting feedback from something. so now i am like wtf it was working 100% a few minutes ago. so i pull the inline fuse out for the orion 1200d (o i am running 2 sets of 4 gauge wiring) and i still have that problem.
so my buddy is telling me that my power wire (12v) are too close to the RCA (preout wires) and i need to move them to the other side of the car... does this sound right to you guys or did i fuk something up.
i didn't touch the orion 4002 at all during the instal of the 1200d.
so i have no idea what is wrong os if someone could be so kind to help me out that would be hot!
so thank you to all who read this and to all future helpers!
Kenneth
That sounds about right, running everything down the same side with the 4002 was a bad idea in the first place, but if it was not giving you any problems then I say screw it let it be. However, when you added that second power wire, you increased the chance of picking up noise in the system.
I would def move those RCA to the other side of the car and see if that makes a difference.
alrighty i ran the RCA's over to the other side of the car and yes it made a little differences but i still have the feedback but not as loud as it was before. i also jsut moved my ground wire and no differnces. so now i am going to hook an mp3 player up to the amp and see if it is still there the feedback that is. and if the feedbakc is gone then i know my problem is with the rca cable in which i will have ot run a new one and if it is still there then i don't kow wtf is going on
Kenneth
WHOOA problem solved thanks you to everone who helped me out!
i had to do a ground loop on my deck from one of the pre-outs. since i have a 8800 premier deck lol! anyways simple fix but i spend to many hours trying to figure out what was wrong but with some dicking around and some luck it has been solved!
again thanks to all and to all a good night! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Kenneth
CrazyKenKid
CrazyKenKid
Canada
CrazyKenKid
