you got actual data to back this up?yellow also has a lower internal resistance
I didn’t say it wasn’t important…I said their low ESR isn’t accurate. If you worked there then you would know any proper ESR testing of a battery requires ESR graphs over the total potential vs different temps vs different loads. Where is this information and what are the surrounding conditions of the ESR reported.with 2 nines in back i would get at least a kinetik hc 2000(102 aH) vs the 800. Thnking the esr is important as its the actual load it has in the system
Reaction rate of the battery is dictated by the type of reaction and properties of that reaction, ESR is a factor in amplitude of discharge and recharge rate (discharge rate is governed through external impedance or equivalent of, as is recharge amplitude).plus it effects its speed and ability to do bursts.
Duty cycle of the load (for lack of a more comprehendible definition) is the dynamic factor, Duty cycle of the alternator remains constant. It’s typically .7ms. This is the reason the alternator voltage drops, but as I said in my earlier statement voltage shouldn’t drop for any significant amount of time, I base this on duty cycle and rate of load vs source.An alternator doesnt produce 100% constant amperage 100% of the time it depends on how fast it is spinning.
It still will cycle, just not for any noticeable time. And even if there is absolutely no load on the battery it’s still constantly cycling due to leakage.your comment over the voltage then the recommending of a deep cycle for longevity contradicts. if i understood you right the battery wouldnt get drained as such
