Optima Yellow Top 34/78 vs. Odyssey PC 1200MJ
wingsofwar20
I am getting a new battery to power my monster system. I am looking at both an Optima Yellow Top 34/78 and an Odyssey. Both can be purchased for under $160.00. Honestly I'm leaning toward the Odyssey. I just though I'd get some input from you guys. Heres the specs:
Odyssey PC 1200MJ Specs:
* 1200 cranking amps for 5 seconds
* 1090 cranking amps for 10 seconds
* 900 cranking amps for 20 seconds
* Short circuit current over 2600A
* 78 minute reserve capacity with 25amp load
* With metal jacket and female brass terminal w/M6 SS bolt
* Length 7.87"
* Width 6.66"
* Height 7.55"
* Weighs 38.2 lbs
Odyssey design:
* 3 year full warranty
* Rugged Drycell sealed design
* Military grade
* Vibration resistant
* 60% more starting power
* Deep discharge reserve power
* 2 year storage life
* 8-12 year design life
* Can be mounted in any orientation
Optima Yellow Top Model Number D34/78 Performance Specs:
*Voltage 12v
*Cold Cranking Amps @ 0F 750
*Cranking Amps @ 32F 870
*Reserve Capacity 120 minutes at 25amps
*Capacity (C/20 Rate) 55
*Internal Resistance (ohms) .0028
PHYSICAL SPECS
*Length 10"
*Width 6 7/8"
*Height 7 13/16"
*Mimimum Weight (lbs) 43.5
*Type Post/Terminal Dual SAE & GM
*BCI Group 34/78
All thoughts welcome thanx.
//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
where is this battery going to go, i suggest one of scotties G31 yellow tops if he still has any left, 100+shipping for a great battery that looks brand new, if your going for a new batt just pay the extra for a 2150 or so, you will be better in the long rung
* Length 7.87"
* Width 6.66"
* Height 7.55"
* Weighs 38.2 lbs
Odyssey design:
* Military grade
*Voltage 12v
PHYSICAL SPECS
*Length 10"
*Width 6 7/8"
*Height 7 13/16"
*BCI Group 34/78
The only spec. I see that you can use to compare the two above is the reserve capacity. The Odyssey battery that would most closely match the G34/78 Optima is the G34/78 (PC1500) from Odyssey. So... between the two above... the obvious choice is the Optima.
wingsofwar20
wingsofwar20
Oregon
scottiej
