Opinion on amp for 2 sundown audio sa-12s
Ampere audio 2000.1 is also a nice amp to look at,if you have money to spend look at fosgates bdcp amps. But the list can go on and on sq 2200.1, crescendo 2000.1 and sundowns svc amps. It all depends on what you can spend,what's your budget and electrical look like.
If he's not looking to run 1/2 ohm, all those amps are wasted money. They all are 1 ohm stable and power cuts in half when wired to 2 ohms.
I know he's not running 1/2ohm but those amps will still give decent power at 2 ohms. With the ability to run 1/2 ohm instead of buying a new amp .2ohm amps are a lot more expensive than 1ohm amps with the ability to drop lower if need be.
why dont people Fucking READ!?!?! NOT AT HALF OHM!!!!
find yourself a kicker or alpine. theres a few oldschool amps in the classifieds sectin that do those numbers at 2ohms
I have a co-worker that sells me his kicker zxs1500, would that be enough or should i go with something bigger?
depends the price but good enough theyre rated for 600 so technically your overpowering them. but your straight
malandrin4o8
malandrin4o8
San Jose, Ca
malandrin4o8
