You won't get that amount of power to the subs. That's what you're obsessing about. According to every box building program I have, and I have a few, my XXX should be long dead with the 1500w going to it because it reaches Xmax with less than 800 below tuning. Same with my Assassin 8s. Neither of the above has ever broken a sweat. Why? Because despite the rating of the amp, that amount of power never gets to the subs when playing music. The next consideration is that Xmax is where the motor runs out of steam. Mast decent subs have more suspension capability than that it's just that the motor is not strong enough past Xmax to continue to drive the cone in a linear fashion and distortion increases. Until you hit Xlim (the smaller of Xsus and Xmech), you aren't doing any damage to the sub and you're obsessing about a non issue.
Also to demonstrate a point about the effect of a subsonic filter, use Unibox to model the effect of a 18dB/oct filter at around 25Hz. That should fix your excursion non-issue.
