One Tough Choice
Which Sub to go with Until 9152 Ti's
  • Pair of 13w6v2
    Votes: 10 55.6%
  • Pair of 15 RE SE
    Votes: 8 44.4%
  • Total voters
    18
GAM3OVR
Jeka is Back
Okay So I'm trying to find another 15" Eclipse Ti 9152 for my final build on my Subaru, But Until I do, I'm going to run a ported setup with Either:
( I have the RE's and the JL's so don't think of price as a factor. They are already here //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif)
1.) Two 13.5" W6v2's
2.) Two 15" RE SE's
Can't decide which setup to do.
Pro's for JL's:
More Xmax.
Smaller Enclosure
More Power Handling
Not too many 13.5 Drivers in play right now.
Amazing SQ!!!!
Con's for JL's:
Less Cone Area
(Can't use same enclosure for the Eclipse Ti's later) (more work) Yes I'm LAZY. STFU!
What do you guys think?
Help meh Out.
BTW: In my testing w6v2 vs RE SE in optium sealed.
13W6v2 > 15 RE SE
The W6 will sound better, but the SE will have more impact.
If I had to choose I would go with the w6 for all around.
see IDK. cuz XMAX on the w6v2 is > the RE SE
so what it lacks in that little bit of cone area it. in theory makes up for in movement
Very similar products. I give the nod to the JL's myself, but the likely differences between the two could easily be eclipsed by enclosure variations. And sounds like the SE's would be the easier route. Just pick one choice and run with it, especially if its just temporary.
Thanks, would like to know some real numbers on the difference of the 2.
Link to w6v2:
http://mobile.jlaudio.com/pdfs/7798.pdf
13W6v2-D4
Free Air Resonance (Fs): 24.3 Hz
Electrical “Q” (Qes): 0.464
Mechanical “Q” (Qms): 6.700
Total Speaker “Q” (Qts): 0.434
Equiv. Compliance (Vas): 3.94 ft3, 111.6 litres
One-way, Linear Excursion (Xmax)* : 0.85 in, 21.6 mm
Efficiency (1W/1m)**: 87.4 dB SPL
Effective Piston Area (Sd): 100.4 in2, 0.0648 m2
DC Resistance (Re)***: 6.50Ω
Nominal Impedance: Dual 4Ω
Power Handling (continuous): 750W
Mounting Depth: 9.2 in, 234 mm
Mounting Hole Diameter: 12.5 in, 318 mm
Driver Displacement: 0.120 ft3, 3.4 litres
RE SE:
15"
Electrical Q Value -Qes: 0.55
Mechanical Q Value -Qms: 4.3
Total Speaker Q Value -Qts: 0.49
Free Air Resonance -Fs: 22 Hz
Equivalent Compliance -Vas: 209 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 88 dB SPL
Effective Piston Area -Sd: 810 cm^2
DC Resistance -Re: 2.8 ohm
Nominal Impedance -Znom: Dual 2/4 ohm
Thermal Power Handling -Pe: 600 W
Force Factor -Bl: 17.7
Make a box for the Eclipses but cut holes for the JL's thats not too much work even for a lazy *** like myself.
They don't like a box that big //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
knowledge > you
GAM3OVR
Jeka is Back
GAM3OVR
Russia
GAM3OVR
