OMG! A Soundstream XXX-10000D!
btw, here yah go,
Output Power at 1% THD+N:
1 x 2130W @ 4 ohms (13.5V)
1 x 2200W @ 4 ohms (14.4V)
1 x 2268W @ 2 ohms (16V)
1 x 3350W @ 2 ohms (13.5V)
1 x 3700W @ 1 ohm (14.4V)
1 x 3846W @ 1 ohm (16V)
1 x 4770W @ 4 ohm (13.5V)
1 x 5300W @ 2 ohm (14.4V)
1 x 5520W @ 1 ohm (16V)
1 x 10000W @ 1 ohm (17V) ??
S/N Ratio: >80 dB
Damping Factor: >350 @ 80Hz (+/-5Hz)
Operating Freq. (band-width): 15Hz ~ 150Hz
Dimensions: 26.85" x 11.42" x 2.56" (68.2cm x 29cm x 6.5cm)
Max. DC current: 545A DC (1 ohm, 13.5V, 1% THD+N)
Why are there two ratings for some stuff?
Like:
Is that maybe strapped?
we dont need any H/O alts for our competition vehicle. The class we are attending in db drag limits to one battery under hood. Where each burp we do at a comp, we will need to charge the battery asap, to hold upon that constant voltage reading (14.8-15v)
Umm, you do realize the MAX voltage you can have in the lanes is 14v right?
im sure he knows that cause he is using the odyssey 2150 which is a 12v battery //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That doesn't mean anything. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
My el cheapo walmart batts sit at 12.8-12.9
And i've seen yellowtops float as high as 14.5 //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
from what ive seen of them 1 ss 10k puts out the same as 2 powerbass 3k amps at 1ohm in a drop in cenerio @14.4volts dante your gonna need more batt power to run 2 of them cause they draw massive amounts of current btw //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
werd.
danteBirosel
danteBirosel
San Diego, CA
zachzchw
