Old School Dr. Crankenstein M-80 80x2 RMS Brand new with box and manual !
ampjunkielikeme
nash, tn
SOLD ! Item(s) for Sale:
brand new with the box- Dr. Crankenstein M-80 2 channel / subwoofer amplifier
80 x 2 rms @ 4 ohms
160 x1 rms @ 4 ohms bridge
full power bandwidth-20hz-20 khz
thd- 0.03%
imd- 0.004% ?
s/n ratio- 92db
damping factor- 100
AMERICAN QUALITY UNCOMPROMISED
MADE IN THE U.S.A. BY AMERICANS
135 watts per channel instantaneously peak power
on board subwoofer crossover @ 80hz, 12db per octave
the m-80 may be bridged to mono operation delivering 200wrms
input mute function
output protection from short to ground , or to the supplies via internal limiting circuitry .
gold plated rca jacks
supply under voltage protection. eliminating turn on/off pop
output, over voltage protection
plexiglass bottom
deep clear bass
open airy midrange
smooth accurate high frequencies at your command
the manual says: in inches
7.5 L x 5.5 W x 1.75 H
the amp is brand new, and works great! . never been mounted..comes with the box and the manual/ hook up instructions. it doesnt have a scratch on it anywhere. you will never find another one in this shape..
(manual states :to obtain service) send the amp to florida . kinda makes me think USAMPS made it. how many amps from back in the day used a plexiglass bottom ? from what i have read. dr.crankenstein didn't make any of their products inhouse. eminence made the subs. and the amps look like usamps..
the coolest part about this amp is that it can, and will run a subwoofer. and do a great job.. so if you need a small sub amp you can hide anywhere. this is for you
or if you need a amp to run a component set. it can do that as well..
65.00 shipped to the cont usa... no trades..
i wonder what this van had inside it? 20 m-80 amps on 20 eminence subs?...
I remember when this stuff was sold @ Wal-Mart.
it is a good amp. for what it is...
i think they were sold at wallyworld after the company went out of business...
it still has a price tag on the box for $100.00 .... lmao (not from walmart)
I have crank 12's //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
your crankenstein 12's and this amp is a match made for the godzzzzzzzz..... even more powerfull than a funkypup.....for realz..
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
ampjunkielikeme
ampjunkielikeme
nash, tn
jasonspgt
