Yeah, I pic would let me help you a bit more.Originally posted by Zach85 don't I need the 12 volt batt/memory so it will remember the time and my radio settings? I think it will work if I have the power wires (red) all connected, with the Lamp and Illumination connected. It worked before so I think with my new wiring it should work as well?
I have a blue cable with a tape around it labeled "ATT" coming from the CD. What is that? is that supposed to attach to the power antenna from the harness? Also, I have two other blue wires with a plastic covering on the end (seems to connect to something) but I can't find anything that it would connect to! If you want a picture of what I mean I will post one up at your request. By the way, I don't know if the ends of the Orange and Yellow cables as I described earlier is needed to be plugged into something... It looks like a fuse, but it's a bit bigger than one. I hope you have a clear image of what I'm trying to describe. I just looked at the CD Player and it seems that the patch that hooks into the CD player has two openings for something (what... I don't know) and seems that maybe I'm supposed to take the end of the yellow and orange wires and hook it into there? might be a suggestion, but I don't know. Thanks
Yes. You'll probably have to find a place in the fusebox for that, since stock radio's don't usually have a clock. Tapping into the ciggarette lighter wire works - it's on all the time.Originally posted by Zach85 don't I need the 12 volt batt/memory so it will remember the time and my radio settings?
Power antenna sounds right.I have a blue cable with a tape around it labeled "ATT" coming from the CD. What is that? is that supposed to attach to the power antenna from the harness?
Blue wires are generally remote turn-ons for your amps.Also, I have two other blue wires with a plastic covering on the end (seems to connect to something) but I can't find anything that it would connect to!
On most radios, orange is the illumination wire from the light dimmer in the dash, and yellow is constant power for clock/memory.By the way, I don't know if the ends of the Orange and Yellow cables as I described earlier is needed to be plugged into something... It looks like a fuse, but it's a bit bigger than one.
Do you plan on wiring an amp any time soon???Originally posted by Zach85 Tek,
Thanks. The reason why I'm fustrated at this point is because of my friends who (they claim) know cars. One of the 3 plugs (blue one for rear speakers) was clipped by one of them who thought that it would be ok to wire them directly to the CD player without the harness. I will be going to the junk yard today or tomorrow, depending if they're open today due to New Years to get a clip to wire back onto speaker wires. Thanks again.
RangerMan, here is a webpage I made (under a website I'm currently working on) that has the pictures. The one is of the blue wires I was telling you about, and the other one is the one with the Orange and Yellow cables that look like they are hooked to a fuse like end. I hope this is useful.
http://www.geocities.com/ccna_zach/carwires.html
Happy New Years
He got one...that is what I told him to get...Originally posted by Gauntlet In your picture, the one where it says "what is this?", look here - http://www.crutchfield.com/cgi-bin/S-KhOdj0TSnj0/ProdView.asp?s=0&c=11&g=103000&I=120701677&o=m&a=0 - you'll see on the right side the female end for that connection, the installation would become 100 times easier if you got a harness. Hope that helps
Illumination connects to the dimmer. You really need a CD Player wiring guide...what model is your CD player, and I'll try to find one...Originally posted by Zach85 Will this work?
Wire - color ------ connected to ----- wire - color
Illumination - Orange ----- Positive Dimmer Orange/white
12 volt batt/mem - Yellow ----- Lamp - Yellow
12 V B/Mem-Lamp - Yellow-Yellow ----- Power (3 of them) - Red
I hope you can read this. If not I'll write everything out in next post.
Gauntlet, that "box" I labeled "What Is This", do I need to plug that in somewhere or should I just leave it as it is? I tried looking for a place to plug it in but can't find anything. Also, that website shows that only the yellow wire is connected to that "box". Why would that be?
