Ok wtf
infamous_e46
hArRy_DaNgLeRs
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif//content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
its possible when tc went bankrupt lanzar got there hands on a basket patent, if it was even a patented basket.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif:confused:
SPECS
Custom Tooled Die-Cast Aluminum Basket
COC Composite Cone
Jumbo Dense Foam Surround
3'' High Temperature Dual 1.2 Ohm Voice Coil
100 Oz x 3 High Density Barium Ferrite Magnet
Power Handling: 1600 Watts RMS /3200 Watts Peak
Frequency Response: 30 - 500 Hz
Impedance: Dual 1.2 Ohm Voice Coil
Efficiency: 88dB
Includes Installation Hardware and Template
Packaged In a Wood Box
I used two of these subs all year with one Opti4000d and they hit hard. When I went to Meca World Finals I put two Opti4000d's on those subs at one ohm and 8000 watts with no problems at all.
They are dual 1.2ohm and 10'' tall at 60 pounds.
Ed Ramos
Team E2 Audio
Team Lanzar
Im pretty sure the lms uses a 4" voice coil, dunno all the specs but there not even close to the same sub. If there cheap enough try a couple and report back.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Since when does same frame = same sub anyway? If that's the case, I guess all MT's, BTL's, Brahma's, old XXX's, old Magnums etc etc all perform the same too? They all use the same basket.
Even just from looking at the pics you can see the motor is different... diff pole vent size. And Im pretty sure Lanzar using this frame is old news... I seem to recall it showing up about this time last CES.
i just wanted people who know more to respond and thank you //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
James Bang
