ok. this is really pissing me off. Pioneer 80prs
Yeah. Thankfully someone answered that. I didn't think about the HU's internal amp.I don't even play the stereo now.
Can't wait to finish it all up the right way.
---------- Post added at 01:47 PM ---------- Previous post was at 01:47 PM ----------
hey. my camry's factory HU doesn't clip either.
can you link to me some single Dins that cost $500+
I couldn't find any
Stage 4 | Pioneer Electronics USA
holy crap. Well of course it doesn't clip. It states it doesn't have an internal amplifier. But wowzer. That is expensive.
what makes it just destroy the 80prs? the 31 band eq? along with the 4 24 converters and the 32 bit?
Clipping
Those are the main reasons it sounds so good, plus it is 3 way plus sub active capable and looks sexy. I'm sure there are other things, but I have never played with one nor really looked into one. It's too expensive for me.
x2 1200 is definitely breaking the bank.
isn't the 80prs a 3 way?
and what is sub active capabilities?
The 80prs is 3 way, high and low front stage plus sub. The p99rs is 4 way, high, mid, and low front stage plus sub. Sub active is the same as any other speaker, I just kinda said it weird in that post.
I thought there isn't much to tweak on subs since the signal is mono.
Hmmm. The HU being 3 way doesn't really mad anyways correct. Because once you run it active. Aren't you relying on the amplifiers crossovers then? The audison has an intense amount of crossovers.
[quote name='jockhater2']I thought there isn't much to tweak on subs since the signal is mono.
Hmmm. The HU being 3 way doesn't really mad anyways correct. Because once you run it active. Aren't you relying on the amplifiers crossovers then? The audison has an intense amount of crossovers.[/QUOTE]
Active vs. passive is concerning the crossovers. Active uses some sort of digital processing, passive is done mechanically with capacitors, resistors, etc. Almost all subs are crossed actively, don't think I have ever actually personally seen passive subs that actually use a crossover, though I'm sure it happens in home audio. Even though the sub signal is mono, you can still adjust a lot, such as levels, crossover points and slope, time alignment, things like that.
The HU being 4 way does matter very much. It allows you to set your crossover points and slopes very accurately on the HU, and doesn't require external processing. Using the crossovers on an amp, if they are there, is usually hard to do because they only have rotational knobs that aren't detented. To get 3 way fronts otherwise, you would need a processor that breaks that signal down and does the same thing. I guess you could run a full range signal out of any HU, split it to 3 channels of an amp, and use the crossovers there as well, but I don't think I have seen that.
When you use the crossovers on a HU, you generally don't use them on the amp, only to get a steeper rolloff at a certain frequency. Not sure how @keep_hope_alive is going to have you set it up, but my guess is you will be using the crossovers on the HU and running the amp as full range. That's how my 80prs is set up at least.
And of course, he will most likely know much more than what I just wrote, and probably point out that I am incorrect somewhere. This stuff gets confusing sometimes, and I'll be the first to admit I don't know everything.
cliff notes? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
when it comes to setting up the HU and amp, I'll just have him call me so we can talk through everything.
the Audison crossovers are much better than the Pioneer crossovers - so we'll use them as much as we can.
the main reason for the HU is T/A.
I was thinking that too. Because the audison has a lot of cross over settings.
Yeah. That will make it much easier.
jockhater2
jockhater2
Saukville, WI
jockhater2
