wanton789
HU: Kenwood KDC-BT952HD Single-DIN
Fronts: HAT Unity
Amp: JL XD700/5
Sub: IDQ 12v3
-with sealed 1 cu ft box
Car: 2002 Toyota Highlander
I understand I will have to tweak it once I get in there, but looking for some wisdom from people who have used these components before.
I will not be using the crossovers from Hybrid and will instead be using all 4 channels on the XD700/5 for the front. Sub will be wired 2 ohm to get ~300 W RMS.
Looking for some advice on where to set the HPFs and LPF initially.
Further, if you look at a picture of the JL amp, there is a HPF setting: x1 and x10. Does this only apply to channels 1 and 2? Or all four channels? (I am assuming only 1 and 2... This is where I will put the tweeters?)
Do I need to look at the resonant frequency, Fs, to help determine where to set the filter? Or is it all just based on environment and specific to each situation?
Don't need too crazy of responses, just if you used these speakers before, where did you set your filter, etc.
P.S. all the components are linked up above
Fronts: HAT Unity
Amp: JL XD700/5
Sub: IDQ 12v3
