Ok, so I got my new sub...now i need more help.
logik05se
Sup fellas
As i stated in my first post I had a 2000 peak, 1000 watt rms fosgate power hx2 blow within 20 minutes on my mtx thunder 81000D amp. I gave the installer the benifit of the doubt because its an old sub.
Today I received my rockford fosgate t210d4 10inch sub. 1600 peak, 800 rms. I wired this sub the way fosgate told me too, positive to positive and negitive to negtive. Everything seemed fine, I was playing wit the adjustments on my amp by work. The gain I have up about 1/4 of the whole way, so its barely up. It sounded real nice and clean. When I got home and had the music low, I noticed that even though the sub was hittin, I heard an odd sound coming from it. Almost like a buzz or a rattle you can say. It still hits hard, but the sound is definatly audible at very low volume. WTF!
Please help.
I know this installer said something about wiring this thing up for stereo (which I dont know why after some research), could this have anything to do with it?
loose inner dustcap or someting maybe?
i really dont know...it will happen from very low volume to high volume. Its definatly 100% coming from the sub because when I turn the gain completly down the sound is no longer herd.
The sub still hits really hard though, so i doubt its blown. I wouldnt really know if its a blown voice coil....its a dvc sub, but once again its hitting excellent so it probably wouldnt be that rite?
Try playing one voice coil at a time and see if you hear the same thing on each side (with the gain up and down). If you hear in only on one side, then you have a bad voice coil, but if you hear it on both sides, you either have an improperly broken-in sub, or a defective one.
tried both of them individually and still herd it.....funny thing i noticed is that when I let the sub rip, and go high volume for a minute or so, the noise would go away and then slowly come back.
my installer nor rockford knows what it is.
Ummm, no, not at all.
A voice coil is wrapped around a former, which moves up and down in the gap due to the changing magnetic field. Hooking up a single voice coil at a time will not diagnose a noise on either "side", because both coils are wrapped around the former.
logik05se
logik05se
brooklyn ny
canadiancav
