ok im guna make this a simple question!!!
jz976
straight to business...i have two orion hp series in the loaded box orion offers..im running an AQ1200 watt amp..i know a sub is only as good as the box its in!!..soo i need suggestions on a new ported box..thats guna make it even louder..id say im hitting in the 143db range...i hit 140db with an orion600watt rms amp but now i got the aq that really pounds but i want to make it even better...suggestions ???
Box with subs-----> http://www.orioncaraudio.com/Products/Products.aspx?ProductID=525
Their are a couple nice box builders on here. Fisher Customs does nice work.
A custom enclosure is always going to be better than a pre-loaded or pre-fab enclosure.
And your right, everything is install dependent. The box in my honest opinion makes the sub what it is. A bad *** sub in a poor box is gonna result in poor sound. A shitty sub in a correct enclosure would sound good.
Or if you want to build your own, plenty of people on here offer box designs. RyanM923 is here local to me and does box designs for a small fee. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i like to get into touch with the rite people on here if u could send them my way that would be nice..i also need to be sure whatever box i have built will fit in my 03hyundai sonata lx... the prefab box fits with sum spare room but im not quite sure how much,.
ive had brian chia design 2 or 3 boxes for me based on vehicle, sub, and ideal freq I wanted for it to hit.
not sure if hes around here still but def a good guy and if you're handy with a drill and some basic wood working you can def build a NICE ported box meant for your setup for under $100
jz976
jz976
Michigan
jz976
