impulsebrklyn
Ok im not happy with my current setup. i just purchased a brahma 10" and i had a audiobahn a18001dq from my last install. I was hoping to push the brahma with it but it wont take the 1800 watts at 1 ohm and it only pushes 600 at 4 ohm. So what to do? Should i just stay with the 600 or should i purchase an amp that pushes like 1200 at 1ohm. Need some advice here. Will the sub perform alot better or alittle better with more power.
Also with the a18001dq it seems like i have to have the gain like 3/4 to full to get much output. Is this wierd bad? When i had my two idmax hooked up to it i only had to have it at like 1/4 but i was running at 1 ohm?
Ok last question is what size ported box should i build for the 10" brahma cause this little .75 sealed box adire told me to build just isnt working well. ????
Is anyone else running a 10"brahma i what are they running for it?
