ohms vs sq
Personally, I ran my JL w6v2's with 1000 @ 1 and then 1000w @ 4ohms on a different amp,
Would had to have been a very thorough setup and testing of the two amplifiers in order to assign any change in sound to a difference in load. Without a very thorough setup and testing procedure, your results are likely biased in some manor making the comparison invalid.....i.e. unable to attribute the difference in sound to a specific variable such as impedance or damping factor.
Currently making a change in one of our sq cars, so this is by the ear and first hand experience.
Past install was an old school Lanzar Opti-Drive 1000d running 1 ohm mono class d on an IDMaxV.3 dual 2 10 in 0.9 cubic feet sealed, switched over too an AB amp and same series Lanzer 500.2 at 2 ohm mono with a dual 4 same box, vehicle, everthing, sub had same use and was bought at the same time, made an amazing change in SQ then switch then went to 4 ohm with the dual 2 ohm sub again a noticeable difference in sq. So take it for what it is worth.
Currently making a change in one of our sq cars, so this is by the ear and first hand experience.Past install was an old school Lanzar Opti-Drive 1000d running 1 ohm mono class d on an IDMaxV.3 dual 2 10 in 0.9 cubic feet sealed, switched over too an AB amp and same series Lanzer 500.2 at 2 ohm mono with a dual 4 same box, vehicle, everthing, sub had same use and was bought at the same time, made an amazing change in SQ then switch then went to 4 ohm with the dual 2 ohm sub again a noticeable difference in sq. So take it for what it is worth.
http://www.caraudio.com/forum/showpost.php?p=4666912&postcount=16
It may have been something other than impedance or DF, but either way, I heard a different sound (for the better) from the amp hooked up @ 4ohms.
ID seems to be thinking that higher ohm would yield better sound. (you can browse their forum - same advices everytime)
Higher ohm = for the amp, less stress, more damping factor = tighter sound
They seem to recommend A/B class amps also because of their higher DF.
Can someone elaborate?
RebelDogg
Badd Dogg
RebelDogg
New Orleans, La
mokedaddy
vegang
vegang
