Ohm question
if ur amp is stable at 1 ohms an matches the rms of ur subs( maybe a lil more) at 1 ohms then yes they would hit harder because the lower the impedance the more power. u should get the audioque sdc2.5's over the type r's if u dont have subs yet. i have the type r's and my friend has the sdc2.5's we both have the same amp(audioque 1200d) and i think his subs hit harder an sound better when there both in the same car.
but u said get more hz? what???
if ur amp is stable at 1 ohms an matches the rms of ur subs( maybe a lil more) at 1 ohms then yes they would hit harder because the lower the impedance the more power. u should get the audioque sdc2.5's over the type r's. i have the type r's and my friend has the sdc2.5's we both have the same amp(audioque 1200d) and i think his subs hit harder an sound better when there both in the same car.
I would have gotten them but they were too much for my budget..the type r's should be close tho..they are good subs.
the final ohm load has nothing to do with "how hard" your subs hit it only changes the output of the amp. logic dictates that if you use more power it will be louder.
ccab
For The Horde!
ccab
Southern Georgia
nineball
