Johnny Drama
Banned
- Thread Starter
- #16
Ill take that.$10 says the experiement either fails or is inconclusive.
If the plane flies., you get $10.
The problem with this riddle is that it is only as difficult as you make it. Some people read it differently, and depending on your interpretation, you have different results. Can a plane, on a treadmill, unrestrained and tries to take off eventually build up the airspeed to take off? Without question, it's retarded to think otherwise. Can a plane, on a treadmill, where the speed of the treadmill constantly matches the speed of the wheels (implying friction), eventually take off? No, not within the constraints of the question. Therefore, the way mythbusters tests this riddle depends entirely on if their interpretation matches your own, meaning betting on something that may not even happen is kinda silly.
Which is why I am betting on the show's conclusion rather than the actual results of the experiment. I don't know enough about physics to know whether it will fly or not. But I do know enough about the show to bet the hosts are unable to succesfully "bust" the myth. That is why I chose inconclusive, because I think it will halfway work, but the design of the experiment will cause failure. Knowledge of physics isn't as important as knowledge of probabilities in this instance.The problem with this riddle is that it is only as difficult as you make it. Some people read it differently, and depending on your interpretation, you have different results. Can a plane, on a treadmill, unrestrained and tries to take off eventually build up the airspeed to take off? Without question, it's retarded to think otherwise. Can a plane, on a treadmill, where the speed of the treadmill constantly matches the speed of the wheels (implying friction), eventually take off? No, not within the constraints of the question. Therefore, the way mythbusters tests this riddle depends entirely on if their interpretation matches your own, meaning betting on something that may not even happen is kinda silly.
except the plane doesn't have a rope it has air. So comparing the 2 would be like making the rope never ending so you would never pull yourself forward. A plane needs lift on its wings. The engine will make the wheels go forward but since the conveyor is essential taking that away the plane will never build up lift. This should be an easy 10 bucks for me. Unless they screw up the experiment. I dont think they will be able to control a conveyor good enough.Um...Yes the plane will still take off no matter how fast the treadmill is going in matched speed.As stated...rollerblades, treadmill, rope tied to tree...Can you pull yourself forward?
Now, betting discussion only. Put your money where you mouth is or GTFO my thread nub.
If the experiement fails then you win.except the plane doesn't have a rope it has air. So comparing the 2 would be like making the rope never ending so you would never pull yourself forward. A plane needs lift on its wings. The engine will make the wheels go forward but since the conveyor is essential taking that away the plane will never build up lift. This should be an easy 10 bucks for me. Unless they screw up the experiment. I dont think they will be able to control a conveyor good enough.
'except the plane doesn't have a rope it has air. So comparing the 2 would be like making the rope never ending so you would never pull yourself forward. A plane needs lift on its wings. The engine will make the wheels go forward but since the conveyor is essential taking that away the plane will never build up lift. This should be an easy 10 bucks for me. Unless they screw up the experiment. I dont think they will be able to control a conveyor good enough.
if the initial thrust isn't matched by the conveyor then this experiment = fail'
The planes "rope" is its propeller. Since the propeller has no control over the wheels just the air around it, it will generate enough forward thrust to move the plane forward.
So even if the runway is going 75mph backwards and the plane is thrusting forward, the initial thrust from the plane will allow the plane to move while the wheels move twice the speed of the runway...overtaking its issue.
if the initial thrust isn't matched by the conveyor then this experiment = failfor this to be done correctly any forward movement by the plane must be matched.
incorrect, completely. you would have to actually apply force to the plane itself in order to stop the planes movement. and that is not the test in question.if the initial thrust isn't matched by the conveyor then this experiment = failfor this to be done correctly any forward movement by the plane must be matched.
you = faster fingers //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gifIncorrect...
The max speed of the conveyer can only be the speed of the planes takeoff. So if the plane needs 100mph the conveyer can only do 100mph.
The plane can throttle up and move forward...
As far as the experiment messing up...
Flip and myself have a "side bet" Either they(mythbusters) mess up or the plane takes off.
Everyone else is either pass fail. They prove it is true you get paid. They prove it can fly, I get paid. They fail at making a working model...the bet is null.
i wanted in on that side bet //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
check out my earlier post. i said the same thing, plane will take off assuming they dont screw it up. but i am pretty confident they will screw something up...I dont have full confidence in them so I dont want to lose all my money from that bet. I do however have full confidence that the plane will take off, so Ill take that bet.
