silenkiller
So, I noticed that when you go past like, 18/60 on the headunit, there is an audible hiss, like a hum, that can be heard behind the music. If you pause the song you can really hear it. Also, if you pause the song and then turn up the volume really high it gets very very loud.
I was thinking ground loop of course, but I've switched grounds twice now and still no luck. Maybe I shouldn't have my grounds shared with my sub and comp amps? I even tried tossing in a loop isolator and it didn't do anything.
Any suggestions?
Should I run my grounds directly to the battery terminal maybe?
Any suggestions?
