o-scope & gains questions
RemlapaN
PA
ok, i did the whole search thing, read some stuff on bcae, and its all making sense. However, a few questions:
I have a small handheld scope, which i plan on using to set amp gains. I found the clip point of the HU (playing sine waves and watching the scope).
The amp i am using is a 4ch amp, 2ch's for mid-range, 2chs bridged for a pair of 10" subs. THe scope im using says it can calculate watts if you tell it the impedance, so i did this. It has two settings for RMS Watts: AC, or AC+DC. Which should I use? AC always seems to read kinda low, AC+DC always seems to read kinda high.
Basically, the amp can do 800wRMS (or so it claims) at 2ohms, but my subs only handle 150wRMS each, so i need to set my gains to keep it near 300wRMS @ 4ohms (since the subs are wired in parallel).
Is it as simple as playing a 50Hz tone, and setting the gains to 34.64volts? ( sqrt( 4ohms * 300watts) )
4 ohm subs, two of em wired in parallel. But in reality, whats the difference if i set it for 300w @ 2ohms, or 150w @ 4ohms, its the same reading.. ahh, i just realized i calculated it wrong above //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif thanks for pointing my faulty math out. Make that 25V at the terminals.
one more question:
Is there any way using a scope to see what your crossovers are set at? I set them by ear first, and then tweaked them alittle more, but I was wondering if you can use a scope to determine precisely where the rolloff begins? (Maybe using a square wave or something else?)
LOL, yeah i was doing that, but as i was sitting there changing tracks to get different test tones playing, i was thinking "There HAS to be an easier way"... so i take it the short answer is "yes there is another way, but its not worth the time or price of equipment to do it"
doesn't this graph show the slopes for 1kHz crossover points? the web page says its 650 hz?? im confused //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
its from this web page:
http://www.bcae1.com/xovrslop.htm
I believe the crossover point is -3 dB when talking power, or -6 dB when talking voltages. That's the 50% point. I much prefer to use a scope for that, since some DMM's have very crappy frequency response. My Sears DMM starts rolling off fast at 900 Hz.
RemlapaN
RemlapaN
PA
maylar
