O crap
well my kicker amp died on me, an it turned out i was underpowering it.
So ive been looking to up my eletrical and i was looking for new alts when
i found this > http://cgi.ebay.com/ebaymotors/Delco-Alt-Chev-Malibu-3-1L-Olds-Alero-3-4L-1997-99_W0QQcmdZViewItemQQcategoryZ33573QQitemZ7995842873QQrdZ1QQsspagenameZWD1V that is my stock alt .An i know reg voltage should be 14 is says that my alt is 12v! so i guess it puts out 12 an below //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif . Well now if i up grade to a 14.4 or w/e will it fry my eletric? Can some one shed some light on ware i can get a 14v for around $200 or soo.
You also did not blow the amp from underpowering it. Your amp has a non-regulated power supply capable of making power more than likely as low as 10 volts before the underpower / overcurrent protection circuit would kick in sending the amp into protection mode. More than likely what killed your amp was a bad ground or running it at the wrong impedence.
haunther
Banned
haunther
Melbourne FL
forbidden
