oceanhawk Member 70 0 chicago Dec 11, 2015 #1 Just as the title states, should I keep that sub at the rated rms or do you think I can safely push more watts into it on a consistent basis? Click to read more...
mazdakid 5,000+ posts CarAudio.com Veteran 11,667 17 illnoise Dec 11, 2015 #2 I'd stay at or under rms until you can tell what to listen and smell for when over powering a sub.
J jboy2015 Senior VIP Member 304 0 Socal Dec 11, 2015 #3 you might not even need to feed it rated power. ie, box made larger than spec for efficiency
hispls 5,000+ posts CarAudio.com Veteran 13,451 1,865 Central Maine Dec 11, 2015 #4 If you even have to ask, you have absolutely no business attempting to use it outside of manufacturer recommendations. *EDIT* Actually if you have a good bit of disposable income go for it and you can learn the expensive way what it will or will not handle.
J jboy2015 Senior VIP Member 304 0 Socal Dec 11, 2015 #5 If you even have to ask, you have absolutely no business attempting to use it outside of manufacturer recommendations. *EDIT* Actually if you have a good bit of disposable income go for it and you can learn the expensive way what it will or will not handle. Click to expand... This is what I was originally going to say. Lol
Papermaker85 5,000+ posts Banned 13,746 28 New orleans LA Dec 11, 2015 #6 At those levels a slightly clipped singal is alot more heat than say 1000rms. If you have the power and its clean with no real voltage problems it more than likely will..
