now this is what i call flex and excursion :)
I've done it...well atleast 2
Those DD's are impressive
No, you havent. 2" MAYBE.
The truck that did that does a 165 on the AC and has over 10kw. Its a 'Daily Driver" system as well and is reletively flat down to 25Hz. It also set off car alarms on the top floor of a 5 story garadge from the bottom floor ramp.
S-10's have a very thin sheet for the roof, they are very easy to do it to.
I'm sure it was 2" before the sound deadner went in. Now it doesnt shake at all really....but its only a 154, 155 ish on AC
My roof barely moves, maybe not even at all....
One layer of second skin, doing over a 150 in the kick. I guess it may be different for newer style s-10's, but with how small the roof is, the curvature to it, and the stock bracing, thats pretty much the only panel that DOESN'T move on my truck. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
a 55.x with no voltage and amps going into protect is nuts. i guess a 58x full tilt burp. that is with out a doubt the sicked car ive sat in, minus chris's caravan
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif x69
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The truck I'm talking about literally broke the rib things. Then then put 100lbs of dynamat in there and it still flexes a little.
Rangers on the other hand. I cant get my roof to flex for shit either. The back wall moves a bunch even with two layres of second skin, same for the door skin...the roof and the windsheild...nothing.
you sat in my car when it had 2 2500D's //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif this is a tad more power than that //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
TypeRBass
Walls are for wussies
TypeRBass
Tinley Park, IL
audiolife
