paintballproam
Hey i can change this
I have two 12" memphis PR's wired at a 2ohm load on an alpine mrp-650 amp. When i first hooked it up, i didnt bother setting the gains or bass boost on the amp or anything. I had the gain turned up pretty high, and the bass boost all the way up (+12) db and when i was testing everything out i had the subwoofer adjustment on my headunit on +15. It was Fking loud. I couldnt hear any distortion. Well, i finally got around to setting the gains and i turned the bass boost, subwoofer adj, and gain all the way down to start with. I was using a DMM and had my HU on like 80% of max, then i Started turning the gain up a little, till i got to NOM, then turned up the bass boost to like +6db, then turned up the gain a little, then the bass boost and i ended up with the bass boost at +12 and the gain in the right spot for the DMM to read 34.2v. Which would be right around 600rms.
Then, WITHOUT the subs hooked up, i turned the subwoofer adj up to 15 and the DMM read 50v. Just throwing this out there, i turned the subwoofer adj back down.
The only thing is, now that the gains are all set, its not that loud any more and im kind of disapointed.lol. Is there anything i can do, other than buy new subs, to get it louder?
