Not for the non believers and standard box builders I need innovators !!!!
NMBR1SPT
I Might Be Your Dad.....
I am looking for somebody that likes to be challanged and when somebody says it cant be done, it makes them wanna do it more, being that person my self //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I posted before and can't seem to get an answer good answer, I need box dimensions for a 08 ford focus, I need the best port and sub firing directions, I have bought the equipment already, I am using 2 threatcon2 15's with a sound stream ta2000d , i have done the big three and have 0gauge power wire already run. these are the biggest dimensions of the trunk , I greatly appreciate any help, thanks I will take photos of the build and send them to you
Trunk dimensions this leaves 8" from the back of the car and the rear seats also fold down , car is a 4 door
20.5 height
41 width
21 depth #1
32 depth #2
Specifications on subwoofer
15" Threatcon-2 Subwoofer
600 Watts RMS
Available in Dual 4 Ohm and Dual 2 Ohm
Dual 2 Ohm: Threatcon-2 15d2
Dual 4 Ohm: Threatcon-2 15d4
3" Copper 4 Layer Voice Coil
Double Stacked 160 oz Magnet
High Current Flat Woven Tinsel Leads
Dual Spider Pack
Dual Stitched Non Pressed Paper Cone-
with Mid Excursion Foam Surround
Enclosure Recommendations:
Sealed: 2.0 - 2.50 ft^3
Ported: 3.0 - 4.0 ft^3 @ 35hz
T/S Parameters:
15" Threatcon-2 Dual 4 Ohm
FS: 38 Hz
VAS: 62.7 L
QES: .54
QMS: 3.72
QTS: .48
Le: 2.89 mH
BL: 26.7
MMS: 253.8 g
SENS: 89.8 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 15.5"
CUT OUT DIA: 14.125"
MOUNT DEPTH: 7"
I am looking for somebody that likes to be challanged and when somebody says it cant be done, it makes them wanna do it more, being that person my self //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I posted before and can't seem to get an answer good answer, I need box dimensions for a 08 ford focus, I need the best port and sub firing directions, I have bought the equipment already, I am using 2 threatcon2 15's with a sound stream ta2000d , i have done the big three and have 0gauge power wire already run. these are the biggest dimensions of the trunk , I greatly appreciate any help, thanks I will take photos of the build and send them to youTrunk dimensions this leaves 8" from the back of the car and the rear seats also fold down , car is a 4 door
20.5 height
41 width
21 depth #1
32 depth #2
600 Watts RMS
Dual Spider Pack
T/S Parameters:
FS: 38 Hz
VAS: 62.7 L
QES: .54
QMS: 3.72
QTS: .48
Le: 2.89 mH
BL: 26.7
MMS: 253.8 g
SENS: 89.8 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 15.5"
MOUNT DEPTH: 7"
my wife has a 03 focus and we have a kicker L7 square in here trunk, and its sub & port forward. her box is around 5.6 cubes gross and right around 5 cubes net i believe. we had fun getting it in there though. we had to take the top of the box off and remove the top of her back seat as well as the paneling from behind that seat. but we got it in though lol...
20.5 height
41 width
21 depth #1
32 depth #2
600 Watts RMS
Dual Spider Pack
T/S Parameters:
FS: 38 Hz
VAS: 62.7 L
QES: .54
QMS: 3.72
QTS: .48
Le: 2.89 mH
BL: 26.7
MMS: 253.8 g
SENS: 89.8 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 15.5"
MOUNT DEPTH: 7"
with that sub only needing 3 cubes net ported you shouldnt have any problems
Lol I figured I was gonna have to assemble in the trunk lol //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif how's it hit?
for that sub you shouldnt.
and with hers does pretty well for all stock electrical and only 6 gauge power wire lol... shes does about 143.8 or so on a music average for 30 secs. if i upgraded her power wire and added a 2nd batt in back she would probly gain a bit from that but shes happy with it the way it is
---------- Post added at 05:15 PM ---------- Previous post was at 05:14 PM ----------
I put it in a calculator and it says I have 10.7 without port or sub displacement
put what in the calc
Trunk dimensions to make sure I had enough space
Can any body plug this in and get me box dimensions? Please? Port size n length I'm having probs with //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Build it in the trunk...and 3ft3 net each is small for those subs.
What do you suggest ? I'm open for anything, I just hate doing things twice lol //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I'm one of those guys I like to do it right the first time. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
NMBR1SPT
NMBR1SPT
Orlando, Fla.
pro-rabbit
