Not as Loud as I expected....
Look at that diagram, no RF speaker has the positiives on the same side. The red at the top is correct, the other red is supposed to be bottom right. I seriously can't believe nobody sees that big mistake, it seriously is confusing to me how you guys didn't spot that.
Thats why his subs aren't hitting, that diagram is wrong from 1 Km away. Sadly, many commercial sites use that type of diagram.
http://www.bcae1.com/ On right side of page, scroll to #58 and click. Look at a single DVC hook up and see the correct way.
it doesn't matter which side the + or the - is on. The point is that the + connect to the other +, in which case we call it parallel.
Below 30, you need to die. Go ahead, flame me all you want, everybody here will back me up, just get out of here already and quit stirring the pot. Read and LISTEN to what others have to say, don't oppose everything when your assumptions are false.
Dont you see, he is having these problems, because the diagram shows to hook one P to the P at. top, then one P to the negative at the bottom of same side. I think maybe you guys are just pretending not to see the problem with the diagram.
Clearly the diagram shows 2 positve on one side of the woofer, when the positve terminals are on opposite sides when you look at bottom of woofer. I actually think they did it on purpous, to make people buy more powerful amps, thinking they are under powered.
Your post proves your a true weak ****, because I am correct 100% in this matter. You fail to go to the link i provided and see for yourself. You are off topic, just to respond to me.
I like my females and don't need no male attention.
You're. Come on now, you can do it, I know you can. (At least I hope your lacking mind can grasp this simple concept.) You're, as in you are.
OK..i am looking at the diagram..
+ to +...check
- to -..check
what is there to be wrong about other than the fact that its on the wrong side? Infact, I don't even know if it's wrong to have the + on the same side. There are no right or wrong way to place the + and -, as long as the polarity is correct.
You're a moron ... Anyone who listens to you is a moron ... Anyone who even hangs out with you on a regular basis must have some serious mental problems ... Your parents probably committed ******* when you were five unless they're ****ed up, too ...
I feel really bad for his parents, they must have had to put up with a lot of ignorance and stupidity during his growing up, but as they say, the apple doesn't fall far from the tree, I hope for their sake it is different though.
Which Rf speaker have any of you every seen, where 2 positve terminal are at top and bottom of the same side. Which one of you went to the site I put up. I am the only one here with facts and the rest of you are just here to be off topic.
Try to speak on the topic with proof, its not that hard.
but does he have rockford speakers? and besides... as long as you wired the positives and negatives right on the sub... what would it matter ?? some subs the positives are on same side... some aren't....
Who cares. The picture is correct, it gets the point across. It's not there to be 100% accurate as in real life, it's there to instruct, and that it does, and does it well. Stop bringing up useless little technicalities that just further complicate matters.
The diagram shows 2 positve on the same side, that is wrong on every single level you could imagine. Why haven't you gone to the site I provided, are guys afraid or something.
We know that they are in a diagonal pattern on real life subs, but the pictures are not meant to be 100% accurate, they get the point across, that is all. All they are telling you to do is positive to positive, negative to negative, NOT which terminals you are PHYSICALLY supposed to wire together. A 5 year old could grasp this concept, red to red, black to black, but you just have to attempt to show your higher level of intelligence( :hilarious ) by complicating things.
So you actually forgot what this thread was about. If a 5 year old could get it, why did the thread starter make this thread. He obviously didn't get it and it was because of that diagram.
I must say I am glad you guys finally admit the diagram is not right. Not sure why it took so long. The diagram is still misleading, because in series, you are supposed to put negative on a postive terminal at some point and same with postive on a negative.
ssj2xxgotenxx
The Chan Man
ssj2xxgotenxx
Bay Area
ssj2xxgotenxx
