ddotmueller13
I had 2 12inch subs with amp in my truck. 2005 silverado extended cab. But I was running the factory head unit. Everything worked fine. I replaced the head unit tonight with a JVC KW-R920BTS. The install went fine but now as soon as I turn the radio on it has a static noise, even with the volume off. The antenna is hooked up fine. I ran the ground trough the wire harness. The amp ground is good. Is there a setting I need to change? I know the shop that did the install had to add something to make it work with the amp and subs. Is that something I am going to need to take out??? Lots of questions thanks
