Noise Resistant Alternator
Resist noise?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
But as far as I know, no there is no such thing.
haha i didnt know alternators were such a high problem with noise
Perhaps his is goin out and you just need a new one
why does it need to resist noise, it doesnt have ears
//content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
Has anyone ever had an alternator that charged the battery but was noisy and replaced it to eliminate the noise?
How do you trace a bad ground that's not audio system related?
I have removed amps and headunit and I'm still getting noise through speakers?
hahahahaha you mean a alt whine coming through your system...ahhhhh....its not your alt. fault (rhymed).....i thought you meant the noise was actually coming from your alternator. Trace all your wires or rcas, and try a new set of rcas or run them down another side or place...good luck:)
newB //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The rca's are jl audio, their supposed to be the best, right?
I've literally removed all audio power equipment from the vehicle, amps and headunit, leaving only speakers and wiring.
So it can't be audio system related right?
Just cuz they may be good doesnt mean they were installed right to prevent the problem
How are your speakers even turning on?
ghost whine.. happens all the time.
try removing the "ECU"... you should be able to google your car make and model and find where its located. they cause a lotta problems weith car audio.
vincent714028
vincent714028
Talladega, AL
vincent714028
