Noise from subs with engine idleing, engine off, and HU off...
sxpimpin
bishes aint shiiiz
Alright so I swapped out amps for my subs. Hifonics goliath to a stetsom 7kd. All grounds, rcas, and remotes remained in the same location. With the stetsom im getting a very loud sound through my subs. Its loudest with the engine idling. It seems like a ground loop by why now after having the goliath with no noise?? I can turn the HU off and you still hear it. I can turn the truck off and you hear what sounds like a magnification of the stetsoms internal fan from the subs.. any help appreciated!
Hang on I had a similar issue I'm going to try and find that thread to see if it could help... although it's strange because grounds remained in same place...
edit: Nvm... my issue was that I was grounding through the RCAs... which unless your grounds are terrible shouldn't be the case...
sxpimpin
bishes aint shiiiz
sxpimpin
pensacola,FL
Imtjnotu
