no power to jvc headunit
t1990le
i am wiring up my duddy's jvc radio in his truck and for some reason whenever the truck is cranked or is in acc the radio will turn on long enough to display a good bye message and then turn off. immeadiate help is appreciated since im working on the truck right now lol //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
check to see if the antenna is got a good connection. that was my problem in my civic.. wouldnt stay on for nothing then i took it out and checked everything and the antenna wasnt getting a good connection
u can try runnin the 12v battery/constant (yellow wire) to the fusebox or straight to the battery, its possible it could fix it, because if the original wire in the car may have been messed up in some way.
I forget what wire it is but its one of ur power either the acc or battery one, i had same problem either you wired it wrong or backwards. Also possibility the actual factory harness itself get a volt meter and check with key off on and started figure out which is which. easier to explain over phone 361 232 8939 if u dont understand figure it quicker then trying to be on forum and back out to car haha
i get the feeling he's out there figuring things out? lol
lol yupp i never could get the thing to work. Well it all started with a call sayin hey my hu wont turn on lol. i told him id come over and check it out. when i got there he had no wirein harness and no dash kit lol after 90min of headache i got all of it but the memory problem to work out. I have some aftermarket speaks me and him are gonna play with tomorrow so ill try the wire direct to batt from hu tom that u mentioned bullet. The truck is a Mazda B2300 the stock HU has a ford wiring harness (go figure)
t1990le
t1990le
Kennesaw, Ga
t1990le
